To configure and enable an EAPS protected
ring, do the following on each ring node:
- Create an EAPS domain and assign a name to the domain as described in Creating and Deleting an EAPS Domain.
- Create and add the control VLAN to the
domain as described in Adding the EAPS Control VLAN.
- Create and add the protected VLAN(s) to the domain as described in Adding Protected VLANs.
- Configure the EAPS mode (master or transit) for the switch in the domain as described in
Defining the Switch Mode (Master or Transit).
- Configure the EAPS ring ports, including the master primary and secondary ring ports, as
described in Configuring the Ring Ports.
- If desired, configure the polling timers and timeout action as
described in Configuring the Polling Timers and Timeout Action.
- Enable EAPS for the entire switch as described in Enabling and Disabling EAPS on the Switch.
- If desired, enable Fast Convergence as described in Enabling and Disabling Fast Convergence.
- Enable EAPS for the specified domain as described in Enabling and Disabling an EAPS Domain.
If you configure a VMAN on a switch running EAPS, make
sure you configure the VMAN attributes on all of the switches that participate in the EAPS
domain. For more information about VMANs, see
VMAN (PBN) and PBBN.
